ok, is 19210737 the same as 12607096// gm says this ecm its compatible with 2006 ctsv
what i need is to run a 2006 ctsv os and tune it for my lsx376
If your GM technician says it is compatible with a 2006 CTS-V - then have him give it a try.
As I stated previously - the controller is blank - will need to be programmed via a Tech 2 type device.what i need is to run a 2006 ctsv os and tune it for my lsx376
Do you own EFILive software ? Or are you just hoping for some no cost DIY advice ?
Regards,
Taz
looking for an advice... not trying to buy the wrong ecm ,, I know they come empty the tuner can install the ctsv os, he just dont now if compatible. with either ecm.
now i can get the ls3 e-rod ecm from gm but from what they tell me its not tunable
This website is for users of EFILive software to assist each other with tuning issues. This is not a DIY project website. Given that you will be using the services of a tuner (professional or otherwise), and are not actually the tuner yourself, and don't even own an EFILive interface - I would suggest you resource your tuner to answer your questions.
Regards,
Taz
well taz thank you for being a Bleep! not like you help alot by answering my questions...
dodnt worry i wont use this site no more.
You are most welcome ... coming from a parasitical moron like yourself ... that is high praise indeed.
Regards,
Taz
