Results 1 to 7 of 7
Thread: Firmware/bootblock update problem
    Aug 2010
    Default Firmware/bootblock update problem
    Im still trying to learn efilive and tried to update my v2 flashscan with the newest update. I havent updated it since i bought it almost two years ago and just did the most recent update and now it will not flash my truck. Should i have updated starting with the oldest update moving forward to the most recent? Not sure what exactly i did wrong so if anybody can give me some guidence it would be much appreciated
    Did you program the BBx files...?
    Aug 2010
    No i havent....can you expand on that? what do i need to do?
    Start the V8 S&T software, click on BBx, click on Tune, create/edit an ECM entry for your ECM, delete any that do not pertain to you;
    if you're going to do BBL, click on Scan and create/edit pidlists for your ECM;
    click Save;
    click Program All (found by clicking the down arrow next to the Program button).
    Aug 2010
    Ok i tried that and it helped but about 30 seconds into a full flash it comes up invalid serial number. what should i do next?
    Thanks again for all your help joecar
    I pm'd Tech Support.
    Quote Originally Posted by jeremybaumgardner View Post
    If the controller is an LS1 or LB7 or similarly aged controller the serial number in the controller may have been erased by a previous dealer re-flash.
    If that happens, the EFILive V7 software must be used to full-flash the controller.
    During a full-flash, the EFILive V7 software will restore an erased serial number. Once the full flash is complete and the serial number is restored, you can then use the V8 pass-thru software or the standalone BBF (Black Box Flashing) to flash your controller.
  1. Trying to update firmware and bootblock
    By nonnieselman in forum Black Box Logging
    Last Post: March 15th, 2014, 03:02 PM
  2. Replies: 4
    Last Post: April 9th, 2012, 03:42 PM
  3. Old Bootblock and Firmware
    By JoshH in forum FlashScan V2
    Last Post: October 4th, 2011, 08:38 AM
  4. How do I update firmware and bootblock?
    By Sparky8370 in forum FlashScan V2
    Last Post: November 8th, 2009, 08:37 PM
  5. Latest Firmware and BootBlock?
    By Highlander in forum FlashScan V2 BB Logging
    Last Post: July 3rd, 2008, 02:29 AM
