I have been running the car in CLSD decided to try out the CALCVET method so i re-enabled my MAF and this was my first log. Are the O2s suppose to hang that much?
Log_0003.efi
Log_0003.efi
You mean on closed throttle... that's ok at closed throttle.
What pid are you using for dynamic air temperature...?
Can you post the calc_pids.txt file you're using.
Thanks for looking at my log, sorry I didn't get back on here sooner. The pcm is an LS1-a pcm so it's a calculated dynamic air temp.
I was looking over my maps that i created and i made the map wrong, i used the calculated VE BEN not corrected so i fixed that but haven't had the chance to run it.
I also didn't reset my fuel trims after I made my changes.
calc_pids.txt
