Results 1 to 7 of 7
Thread: Issues with engine stalling during low speed maneuvering
    Senior Member Wasted Income's Avatar
    Dec 2005
    Default Issues with engine stalling during low speed maneuvering
    I'm having some problems with the engine surging at idle, and sometimes dying during slow speed maneuvering...such as around a parking lot. Seems worse in reverse (maybe it's in my head) but it will become a bit unstable, and usually the engine will die if the steering wheel is on the lock, loading the PS pump. Seems to be only if I tap the gas kinda quick.
    Car details:
    Engine is swapped into a hot rod, DBC LQ4 with LS6 intake, LS6 injectors, stock TB, 228/230 .571/.573 112LSA cam, LT headers, 4L80E with a 3400 stall, and running OLSD with COS5.
    LQ4 Monte Carlo SS_0082.tunDies During Maneuvering.efi
    Can someone please look at the attached log and tune and see if there is anything i could change to help fix that. It idles perfectly otherwise, and drive great around town...
    2005 Silverado Duramax LLY - EFI Live Tuned
    1969 Chevrolet C-10 Pickup - Turbocharged 5.3L/4L80E - EFI Live Tuned
    1975 Avenger Jet Boat - 6.0L/Berkley pump - EFI Live tune in progress
    Lifetime Member BLK02WS6's Avatar
    Jun 2005
    I can't look at tunes here at work - I'll look at it tonight and try to help you out if noone else does in the mean time...
    GM EFI Tuner
    02 WS6 9.41 @ 143 MPH 3675#, drag radials, pump gas, through the mufflers - sold
    Jun 2005
    The attached tune has a couple tables changed - compare to your original tune to see which ones... These tables are used to fix the problem you describe - takes some trial and error as far as how much change is needed...
    GM EFI Tuner
    Dec 2005
    Thank you so much for looking at my tune to make suggestions. It was a "DUH" moment for me...should have looked at those but I guess I wasn't sure how much to tweak it.
    Will give it a try and report back
    Jun 2005
    No problem - glad I could help! With some of the idle air tables, it is trial and error - make small changes till you get the results you want... Let us know how it goes...
    GM EFI Tuner
    Dec 2005
    Quote Originally Posted by BLK02WS6 View Post
    Well I'm chasing a TPS issue now...suddenly it no longer reads 0% when the throttle is closed. Reads anywhere from 0.8%-2%, so it's adding throttle cracker airflow in at "idle". I'll get this nailed down first, then take a look at those other idle airflow tables.
    Jun 2005
    Do a TPS reset...
    GM EFI Tuner
  1. P0606 stalling engine on a 2008 LMM
    By Mitco39 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 6th, 2012, 04:12 PM
  2. Transmission "hunting" at low speed/low throttle
    By skneeland in forum Cummins 5.9L
    Last Post: October 4th, 2011, 09:13 AM
  3. Engine RPM vs Engine speed
    By SPi in forum Gen III V8 Specific
    Last Post: August 11th, 2011, 03:09 PM
  4. low speed surge with TPS at 0.4%
    By The Alchemist in forum Gen III V8 Specific
    Last Post: August 22nd, 2007, 05:34 PM
  5. low speed idle issue
    By Plumber in forum General (Petrol, Gas, Ethanol)
    Last Post: May 27th, 2007, 05:41 AM
