I'm having some problems with the engine surging at idle, and sometimes dying during slow speed maneuvering...such as around a parking lot. Seems worse in reverse (maybe it's in my head) but it will become a bit unstable, and usually the engine will die if the steering wheel is on the lock, loading the PS pump. Seems to be only if I tap the gas kinda quick.
Car details:
Engine is swapped into a hot rod, DBC LQ4 with LS6 intake, LS6 injectors, stock TB, 228/230 .571/.573 112LSA cam, LT headers, 4L80E with a 3400 stall, and running OLSD with COS5.
LQ4 Monte Carlo SS_0082.tunDies During Maneuvering.efi
Can someone please look at the attached log and tune and see if there is anything i could change to help fix that. It idles perfectly otherwise, and drive great around town...
