Results 1 to 8 of 8
Thread: 02 LB7 No Start
    May 2012
    Default 02 LB7 No Start
    Brief summary:
    Truck has a locked, working, EFI tuned DSP5 ECM in it. Purchased EFI and tunes from same tuner, was planning to load on to a spare ECM so I could make changes.
    Acquired spare ECM, installed into truck, no start (I expected this with a different VIN), FULL flashed a stock tune with the correct VIN on it. Still no start.
    Ideas?
    Apr 2008
    do vats relink or just disable vats
    check codes probably geting security codes
    stock sucks
    May 2012
    DOH. Never even thought of VATS...report back shortly...
    May 2012
    Good to go! Thanks tokymon!
    Even the DSP5 works. Strange though that the VIN is still the original VIN and it works...tried changing it in the scan via bi-directional, but it won't let me...
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    Not sure why that is, but you may have to flash a stock tune in and then program the vin then flash the dsp5 tune back in.
    Dan's Diesel Performance
    www.dansdieselperformance.com
    May 2012
    Well, I got the VIN issue sorted out, but now I face another challenge. The truck immediately sets codes of P0700, U2105 & U2106, all indicating TCM loss of communication or failure, however, I can pull information from the TCM no problem.
ID:	13283   Click image for larger version.
    May 2012
    Well, I'm an idiot...because this truck has a relocated TCM (elec fans), I have to fight to get the ECM back in and I cut 4 wires on the TCM harness. All is good now!
    Feb 2011
    same problem with corvette, trying to flash in 1250003 op sys for my 3 bar sensor with pro charger on LS1 and reload tune and now V2 keeps telling me no vehicle detected on stock pcm and roadrunner pcm also says status unknown
    Can anyone help me?
    How can i disable Vats in onboard pcm so V2 will work to install new operating system and tune
    Got roadrunner flashed with oper system alone but no won't let me flash in tune, says no roadrunner detected, tried V7.5 and 8 refresh
  1. LB7 flash and no start
    By JeromeGTO5.7 in forum General (Diesel)
    Last Post: February 29th, 2012, 03:10 PM
  2. Cold start perfect, Warm start flares high
    By samh_08 in forum Gen III V8 Specific
    Last Post: May 12th, 2009, 09:36 PM
  3. Cold start great but warm start sucks."Idle
    By mvvette97 in forum Gen III V8 Specific
    Last Post: October 26th, 2008, 12:22 AM
  4. Where to Start on an LB7?
    By LBZoom in forum Duramax LB7
    Last Post: October 7th, 2008, 07:30 AM
  5. 03 LB7 pcm into 01 LB7
    By red12secz28 in forum Duramax LB7
    Last Post: November 19th, 2007, 10:40 AM
