Results 1 to 8 of 8
Thread: ANOTHER LLY Problem, (cant pull stock file)
    Jun 2012
    Default ANOTHER LLY Problem, (cant pull stock file)
    trying to pull my stock file out so i can flash in a EFI tune, everytime i try i get an error code saying the bootloader failed, retuned to normaln operation
    it has an aftermarket deck, so i pulled the radio amp fuse (if i pull both the radion and the radion amp it always says "ecm connection lost" part way through"
    left the batteries unhooked over night
    tried the driver door open trick didint work
    running out of ideas on this, need some help!
    anyone else have an LLY that was this tricky? i NEED more tips on how to get her done. thanks all
    Jun 2012
    also, i have the current updates as well as current firmwear also.
    Jun 2012
    ok finally got it!, ended up taking the radion fuses out (both of them)
    took the radio head unit completly out
    unhooker the batteries for 30min
    hooked them back up, put the battery charger on it and wa-La! she worked. only took about 6 hours of messing around with everthing to get it all figured out.
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    Let me know how flashing goes.
    Dan's Diesel Performance
    www.dansdieselperformance.com
    Jan 2006
    Next time, try "alt keys" and "low speed"
    Custom Tuning Services
    Apr 2009
    Pass thru only works if only the blue ECM connector is plugged in and rest are out. Fails about 3/4 way through. BBF doesn't work at all.
    Dec 2005
    Funny, I am not having any issues at all, only thing that really screws you over is an aftermarket alarm that interfaces with the CAN Bus
    www.mscservices.net
    Apr 2009
    Just downloaded the June 1st update. Hopefully that cures the issue.
  1. Can't read stock tune out of LLY ECM
    By JoshH in forum Duramax LLY
    Last Post: March 13th, 2012, 10:38 AM
  2. lly.pmm file
    By electricblue in forum Duramax LLY
    Last Post: October 2nd, 2011, 01:33 AM
  3. Stock LLY emission settings?
    By jauregui in forum Duramax LLY
    Last Post: November 10th, 2010, 02:11 PM
  4. cant pull the stock file
    By saltflat in forum Vortec V6/V8 Specific
    Last Post: June 2nd, 2009, 02:10 PM
  5. Stock LLY file?
    By Wasted Income in forum Duramax LLY
    Last Post: December 25th, 2005, 04:27 PM
