Page 3 of 13 FirstFirst 12345 ... LastLast
Results 21 to 30 of 130
Thread: The BOMB'rs new set of lungs....
  1. #21
    Nov 2010
    About 10' of copper tubing coiled creates a heat sink so you can then plumb a sensor in line to measure drive pressure.
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
  2. #22
    It just screams masses of power, love it.
  3. #23
    Senior Member 2006Cummins's Avatar
    Sep 2011
    I had been think of a setup like that too. The more more I thought about it, the more it seemed like it just might work. Thanks for putting the theory to life! Looking forward to seeing how it turns out.
    Mike
    2019 Ram 6.7L 68RFE
    2003 VW Jetta TDI
  4. #24
    Lifetime Member DoghouseDiesel's Avatar
    Dec 2009
    Quote Originally Posted by L31Sleeper View Post
    How can you take pressure measurements with all that heat ?
    -Justin
    Just like this....
    You use the copper line for the first 10' of tube, then use some fine steel wool to act as a filter inside of a 1/8 NPT female - female connector and then the plastic tubing can get run to your gauge or an electronic pressure sensor can be conencted to it.
    This is the setup on my previous turbos.....
    I only use this for tuning purposes, after that I either remove the line and put a 1/8 NPT pipe plug in the hole or put an EGT probe in there.
    1207 HP / 1612 TQ
  5. #25
    Jan 2012
    I'm suffering from some serious turbo envy! My bigger <much smaller than yours> single upgrade is looking pretty inferior. However it looks very exciting.
  6. #26
    Dec 2009
    Started to shine up the hot side before I send them out to coating. Obviously, they won't be shiny after coating, but I wanted the cast parting lines gone and for them to be fairly smooth when finished. I still need to do the "small" turbine housing. The whole hot side will be a grey ceramic, inside and out. The cold side will be powder coated black, inluding the compressor housings. Should match the rest of the motor and truck nicely.
    1207 HP / 1612 TQ
  7. #27
    Dec 2009
    And yes, everything on this setup is one off.....
    1207 HP / 1612 TQ
  8. #28
    Lifetime Member FUBAR's Avatar
    Feb 2011
    One off me one!! Lol. Looks good man. Got any type of goal in my in having the thing back together and running?
    06 LBZ, EFILive
  9. #29
    Dec 2009
    I have the pumps, injectors and head out right now.
    I'm bringing the turbos in to get fresh rebuilds on them today.
    I'm planning on another month before I have it all back together.
    It'll have enough fuel and air for 1200 HP, but I'm gonna run it at around 1000 to the tires so it's not constantly tearing up transmissions.
    1207 HP / 1612 TQ
  10. #30
    Feb 2011
    1,000, 1,200, 1,500, meh, what's the difference...who's counting anyways? Lmao
    06 LBZ, EFILive
  1. WHEEEEW! The BOMB'r is in the 10's'
    By DoghouseDiesel in forum Cummins 5.9L
    Last Post: February 15th, 2012, 06:51 PM
  2. Looking for some help in my WB set up
    By n8dogg in forum General
    Last Post: October 3rd, 2010, 04:45 PM
  3. B8024 Set to 10
    By Highlander in forum E37, E38 & E67 PFI ECM's
    Last Post: August 11th, 2009, 06:30 PM
  4. Need help on tuning for new set up....
    By 12sec.5.3 in forum Gen III V8 Specific
    Last Post: December 20th, 2008, 08:24 PM
  5. says gear set to zero
    By TLKSCHP in forum General (Petrol, Gas, Ethanol)
    Last Post: May 9th, 2007, 10:13 AM
