I did adjust the TTVA up in the low throttle area. I re set the axis to 0,20,40,60,80,100 so that I have more adjustability. By doing that and raising the numbers slightly I have no more flare and a better shift time. I did check the band and it did not need adjustment.
Thanks for the help that was offered, hope this also helps someone else.
