Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: Serial logging and tuning with 2 LC-1's
    Apr 2007
    Default Serial logging and tuning with 2 LC-1's
    I'm sure I read a post on this a while ago but i can't find it. . . I just got done installing two LC-1 units(one for each exhaust bank) in my 2003 Sierra Denali.
    I have them daisy chained together and connected through a taquickness null modem cable. Is there a way for me to log and AutoVE with both? I'm thinking log them as an average?
    Jesse
    Apr 2007
    Nevermind, I think I got it worked out in calc.pids
    Post your calc_pids.txt file, let me sanity check it.
    Apr 2007
    Thanks joecar. I've been away from tuning and EFIlive for a few years and I was new to it then.
    calc_pids.txt
    Apr 2007
    Just tried out the new LC-1 setup and everything seems to be running well in place of the old NB02's. I think I got the PID setup for averaging the two LC-1's but I'm getting no data and this is what it says in "more info"
    PID value cannot be determined because
    the following error would occur:
    List index out of bounds (-1)
    *CLC-00-020
    AFR 10.0 20.0 .3 "({EXT.WO2AFR1}+{EXT.WO2AFR2})/2
    CALC.EXTWO2AFRAV F020 CLC-00-020 AFR WO2-Serial "AFR from Serial WB - 1/2 Average"
    Quote Originally Posted by truethinker View Post
    *CLC-00-020
    On the end of that line you forgot to place a closing quote.
    Same on the end of CLC-00-021.
    Do you use any of the analog wideband stuff...?
    Which pids are you using...?
    Also, the calc_pids.txt file needs two blank lines at its end.
    Also, some of the pids were being calculated out-of-order...
    EFILive calculates the pids in CLC-00-xxx numerical order (i.e. lowest xxx first)...
    some of the pids were being used before they were calculated (i.e. their previous frame's value was used in the current frame's calculation).
    I edited your file a little, see attached, please try it and let me know.
  1. Tutorial: FlashScan V2 Serial Wideband Logging
    By TAQuickness in forum Tutorials
    Last Post: July 22nd, 2015, 09:47 AM
  2. Using inverter for laptop + FS V2 with serial logging
    By Dopey in forum FlashScan V2 BB Logging
    Last Post: September 10th, 2008, 07:37 AM
  3. Need Help w/LC1 Serial Logging
    By TFZ_Z06 in forum FlashScan V2 BB Logging
    Last Post: August 4th, 2008, 02:35 PM
  4. Problems with AEM Uego serial logging....
    By BlackGMC in forum FlashScan V2 BB Logging
    Last Post: July 19th, 2008, 03:53 PM
  5. LC1 Serial Logging
    By oztracktuning in forum General
    Last Post: November 8th, 2005, 05:45 AM
