Results 1 to 10 of 18
Thread: Scantool dvt not working on 02 lb7
    Aug 2010
    Default Scantool dvt not working on 02 lb7
    Hi i'm trying to adjust my railpressure with efi dvt but when i hit active button the car just shuts off, same happens when i try to adjust idle.
    Is there step by step instructions how to do it?
    We will check the configuration for the DVT's on the LB7, but I don't recall anyone having issues like this. The only thing I can think of is when the DVT is activated the value in the slider control is too low?
    Aug 2010
    Yes i think the values are too small the slider gives only 1 and below for the values and it doesnt work,
    if i change the value manually to something suitable same thing happens engine shuts off.
    We checked the configuration yesterday and it looks correct, it 'should' be working ok. This is the first time we've heard of the two controls you are trying to use not working, but, unfortunately we don't have an LB7 to physically test this on, so the only option at this point is if someone else with an LB7 can try as well to see if the problem occurs for them too.
    Feb 2010
    hello!
    I have an exact problem, if I try adjust rail press , if I use slider nothing happens, same thing with the idle speed
    LB7 2001, EfiLive DSP5 , AirDog II, Afe intake , Summit 4"exhaust
    Feb 2010
    Hi!
    any update on this problem? could this be keyboard related, i´m using European setup?
    After trying to adjust the rail pressure using the DVT controls, stop the data logging/monitoring and save a trace file using the menu option: File->Generate error report.
    Then send that file to me at paul@efilive.com
    Please include a link to this thread so I know what it is for.
    Aug 2010
    Hello i send the error log file to you hope it helps to figuring out the problem, if it the log didn't come right please let me know i make new one.
    Mar 2009
    If I get a chance this weekend I will test this on my LB7 to see if I have the same issue.
    2002 Chevy Duramax with a few supporting mods.
    Did you activate the DVT controls and the fuel rail pressure as shown in the image?
  1. Replies: 0
    Last Post: September 19th, 2011, 01:09 PM
  2. dsp 2 switch not working on 01 lb7
    By mpeters0991 in forum Duramax LB7
    Last Post: January 7th, 2011, 08:38 AM
  3. Need help getting my scantool/tuner working
    By Toxicevo87 in forum Gen III V8 Specific
    Last Post: July 14th, 2010, 04:17 AM
  4. LB7/LLY Allison DVT
    By Cougar281 in forum Allison 5 & 6 Speed
    Last Post: May 11th, 2008, 11:26 AM
  5. 03 LB7 pcm into 01 LB7
    By red12secz28 in forum Duramax LB7
    Last Post: November 19th, 2007, 10:40 AM
