Results 1 to 4 of 4
Thread: Error $050B
    Jun 2012
    Default Error $050B
    Updated the E38 engine file and it read fine. The T43 file still shows the ERROR:050B
    Any ideas?
    Thanks.
    Try this:
    Quote Originally Posted by EFILive Error Codes.pdf
    $050B
    Script file not supported by current firmware version
    The script file uses features not available in the current firmware.
    Upgrade the firmware in your FlashScan/AutoCal device and upgrade the EFILive software.
    Then reconfigure FlashScan/AutoCal using the latest firmware and software.
    What V7/V8 build versions are you at...?
    What AC firmware version...?
    After you updated software/firmware did you re-Program the BBx config...?
    Jun 2012
    Got it to work, just had to "program" one at a time. Thx for the info.
  1. Error $050b
    By minytrker in forum AutoCal
    Last Post: April 19th, 2012, 05:51 AM
  2. error 050b
    By electricblue in forum FlashScan V2 BB Logging
    Last Post: September 6th, 2011, 02:27 PM
  3. Newbie with $050B Error
    By razorback_jd in forum AutoCal
    Last Post: February 27th, 2011, 10:00 AM
  4. error code $050B
    By hawaiianstyle in forum AutoCal
    Last Post: January 28th, 2011, 10:53 AM
  5. $050B Error message
    By jennett_c in forum FlashScan V2 BB Logging
    Last Post: July 28th, 2010, 06:37 PM
