Results 1 to 10 of 18
Thread: Wideband Log Help : Clarity Needed
    May 2012
    Default Wideband Log Help : Clarity Needed
    Just want to be clear on this and please correct me if I am wrong.
    I have 2003 S10 with the LS1b PCM (I thnk thats what u refer it to) or 1MB
    I have a 30-4100 AEM Wideband gauge setup
    I have EFILive V1
    I am using my 0-5v white wire from my AEM WB to the EXT-AD1 side orange plug input of the V1.
    I am understood that I use the PLX PIDs which are the same as AEM needs.
    Anytime I want to do a log, I want to always utilize the WBO2? Right?
    I need to keep my PIDs under 24, so I should start my PID list to include the ones listed below at all cost and the rest I need as well for whatever type of log I am conducting?
    I have to log my AEM using the PLX PIDs. The 3 minimum PIDs to do so are :
    EXT.AD1 (calls EFILive to record that external channel)
    CALC.AFR_PLX1 (since AEM uses those)
    CALC.BEN_PLX1 (since AEM uses those) - I dont understand what a base effec numerator is
    The above I basically gathered from the Auto VE Tuning tutorial.
    But I was also prior told I needed to use in my logs:
    EXT.AD1 (same as above)
    CALC.AFR_PLX1 (same as above)
    CALC.W02BEN (different as above) Is this the same as the BEN.PLX? Different and if so why?
    GM.EqivRatio (added PID and I dont understand it either.
    When do I use the top 3? For AutoVE only and the bottom 4 for all other logs/tuneing?
    Or am I missing the noat all together somehow? Thx in advance for schooling me, Michel
    May 2012
    p.s. I would like to do a simple log that has the basic PIDs needed WITH the added WB PIDs needed to be used/saved for when I am looking at my basic engine performance to diagnose, see if the WB is logging correctly,, etc.
    I want a seperate (if needed) PID list that I need when I am soley doing a MAF tune/log and also a VE tune and log.
    I just want to have my ducks in a row for when I dig into those
    Nov 2006
    External pids use 0 channels and you can add a calc_pid to a log afterwards.
    The EFILive predefined AFR pids are for the manufacturers stoic value.
    If the AFR value for EQ 1.00 is close then they can be used but a calac_pid should be made. IMO
    ({GM.EQUIVRATIO} * Lambda) & (EQ /{GM.EQUIVRATIO}) = fail-proof BEN
    LC-1 WBO2
    May 2012
    Quote Originally Posted by mr.prick View Post
    Not sure I understand totally. Joecar sent me a calc_pid to use. Not sure if I added it in my logs or not.
    I know the PIDs I have listed 'show up' on my list in ScanTool and I slect them from the list. But I thoght at the bottom of ScanTool PID tab it shows them adding up when selected
    EXT pids and CALC pids cost zero channels (even tho EXT pids might show how many channels they occupy)...
    so in your calculation of pid channel count, any contribution from EXT pids can be ignored.
    A BEN calc pid using EQIVRATIO (if your PCM has this pid) is better than AFR for various reasons (including what fuel you're running).
    May 2012
    Ok so I should always use EQUIVRATIO (im pretty sure its a PID on my PCM) and use it with:?
    A. EXT.AD1 (external channel)
    B. EXT.AD1 (same as above)
    CALC.W02BEN
    Post your calc_pids.txt file here.
    May 2012
    This is what I have under My Doc/EFILive/7.5/User Confog
    Ok, your correction pid is CALC.WO2BEN
    this pid requires the following pids to be selected: GM.EQIVRATIO , CALC.AFR_PLX1 , EXT.AD1... i.e. item B in post #1 above.
  1. log serial wideband
    By b18cls1 in forum Black Box Logging
    Last Post: February 12th, 2010, 04:46 AM
  2. Can't log serial wideband anymore
    By white01ss in forum Tutorials
    Last Post: October 28th, 2009, 09:39 AM
  3. log and tune files from stock 06 Corvette Z06 urgent needed
    By Treurentner in forum Gen IV V8 Specific
    Last Post: June 20th, 2007, 01:16 PM
  4. Wideband info needed
    By voda1 in forum General
    Last Post: May 16th, 2007, 03:20 AM
  5. Scan / Log basics without wideband 02 s.
    By Boost in forum General
    Last Post: February 25th, 2007, 01:43 AM
