Results 1 to 10 of 11
Thread: tcm read issues on lbz/lmm
    Mar 2007
    Default tcm read issues on lbz/lmm
    I recently update my v7.5 and v8 software and also bootblock/firmware on my flashscan. I did the mistake of updating firmware/bootblock before checking the version i had....not sure if this is where my problem starts. I can read, scan lbz/lmm ecms but not the tcm. In v8 I get error message "controller type can not be determined". Same in v7.5 I didnt have an issues with a Lb7 tcm. Before i brick my flashscan, I figure I'd ask do some research. ?????
    Mar 2007
    The flashscan shows bootblock version 2.07.04 and firmware 2.07.32 in firmware details tab. I'm just second guessing myself about if it took or not.
    Mar 2007
    update....i can read the tcm using v7.5 but not v8
    Did you also program the updated BBx config files into your V2...?
    Mar 2007
    no i haven't.....i've beeen researching on how to do that
    V8 S&T software, click BBx, click Scan, edit the pidlist (delete the ones for ECM's other than your own, add pidlists for your own ECM), cick Tune, edit the ECM list (delete the ones other than your own), click Save, click Program All (click down arrow next to Program).
    Mar 2007
    I'm getting an ERROR $0194: write failure. Do i have to formant config files before i program all.
    Quote Originally Posted by smudge122 View Post
    Yes, That would be the best thing to do.
    Mar 2007
    ok i can read it and i still get "efilive can not accurately determine the controller type" please send %s to support at efilive.com for analysis
    Can you post a screenshot of that here...
    Also, did you email the file to support at efilive.com...?
  1. Can not get V2 to read any TCM memory on 2010 LMM?
    By Mr.Blister007 in forum Allison 5 & 6 Speed
    Last Post: February 15th, 2011, 10:49 AM
  2. LBZ/LMM Passthrough issues
    By Cougar281 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 3rd, 2010, 11:55 PM
  3. cant read 2006 lbz allison tcm
    By mrrattle in forum FlashScan V2 BB Logging
    Last Post: February 27th, 2008, 04:31 PM
  4. Can't Read TCM
    By ARK 99coupe in forum E37, E38 & E67 PFI ECM's
    Last Post: June 15th, 2007, 02:32 PM
