Results 11 to 20 of 22
Thread: Error $FFFF
  1. #11
    Quote Originally Posted by Ryanbabz71 View Post
    Really?
    Previously there was a different screen when I logged data. It had a timer of how long it was recording.
    It is not, sorry, my bad... it is saying which pid is not supported.
  2. #12
    Aug 2010
    Here is a screenshot, dont know what you are exactly asking sorry
  3. #13
  4. #14
    Aug 2010
    Thanks for your help, sorry for my ignorance. Here are a few more screenshots. I could only manually detect it (2nd photo)
Name:	flash memory.jpg
ID:	13363   Click image for larger version.
Name:	manual select.jpg
  5. #15
    Are you sure the vehicle is connected to FlashScan and FlashScan is connected to the PC?
    There is another way to get the OS.
    Connect FlashScan to your vehicle, turn on the ignition.
    Select the following menu on FlashScan's keypad:
    F3 Diagnostics -> F1 Display Info -> F1 Display VIN/OS -> Select ECM.
    The Operating System (OS) number should be displayed.
    Let me know what that number is.
  6. #16
    Aug 2010
    I am using the autocal, I am not hooking a computer to my vehicle.
  7. #17
    Aug 2010
    I have data logged on my truck with no issue, now I am trying to data log on my camaro.
  8. #18
    Have you read out the tune from your Camaro?
    If so, load the tune file into V8 and get the operating system from there.
  9. #19
    Aug 2010
    got it
  10. #20
    The AFRATIO_M PID is definitely supported for that operating system.
    Can you please try logging again, and after you get the "ECM/AFRATIO_" displayed on AutoCal's display, press OK, then (without disconnecting from the vehicle) navigate to the end of AuotCal's main menu until you get to the option "Save Trace". Click Ok to save a trace file, wait until it shows the "Saved..." message, then disconnect from the vehicle and hook AutoCal up to your PC. Copy the saved trace file from AutoCal to the PC and send it to me at paul@efilive.com, thanks.
  1. Replies: 8
    Last Post: March 20th, 2018, 05:47 AM
  2. Error $FFFF when trying to log
    By mgmc in forum AutoCal
    Last Post: November 18th, 2010, 09:39 AM
  3. E38 Locked? $FFFF
    By SBTuner in forum E37, E38 & E67 PFI ECM's
    Last Post: December 29th, 2007, 05:22 PM
  4. Error
    By ASSAMI in forum General (Petrol, Gas, Ethanol)
    Last Post: February 4th, 2007, 08:27 AM
  5. Com Error
    By Neilb in forum EFILive V4
    Last Post: January 6th, 2006, 05:57 PM
