Results 1 to 4 of 4
Thread: 02 LB7 balance rate PID's gone from list?
    Mar 2009
    Default 02 LB7 balance rate PID's gone from list?
    I tried to check the balance rates on my dads 02 last night and the PID's where not even listed to choose them. I was able to check the balance rates fine last time I hooked up to the truck.
    Shawn
    98 silverado 4wd excb 5.7l, zz4 cam,roller rockers, shorty headers, 0411 swap, Flash Scan V1 commercial
    Feb 2010
    LB7 2001, EfiLive DSP5 , AirDog II, Afe intake , Summit 4"exhaust
    Mar 2009
    So I need to update to the newer version?
    Apr 2008
    Check this post out. The guy updated to the latest and all bootblock and firmware updates from the sound of it. If not able try what I mention in post #4 in that post and the link that is in that post. http://forum.efilive.com/showthread....t=balance+rate
    Brian
    2007.5 GMT-900 Chevrolet Silverado 2500HD CC/LB LTZ 4x4 Summit White.
    With the LMM Duramax 365hp/660tq, MW7 Allison 1000 6-speed
    EFILive LMM DSP5 Settings, 500HP, 450HP, 400HP,Tow with Turbine Brake, and Stock HP.
    UA Steamfitter, Local 136 Evansville, IN - Remember if you want to play you got to pay.
  1. LB7 injector balance rates
    By minytrker in forum Duramax LB7
    Last Post: August 24th, 2014, 02:51 PM
  2. LB7 Balance Rates all reading 0
    By Mitco39 in forum Duramax LB7
    Last Post: May 15th, 2012, 10:08 AM
  3. No Balance Rate PIDs?
    By Heartbeat Hauler in forum Diesel
    Last Post: April 15th, 2012, 06:34 AM
  4. Convert Pass Thru Scan PID list to BBL PID list
    By jrh in forum FlashScan V2 BB Logging
    Last Post: July 5th, 2011, 08:09 AM
