Results 1 to 3 of 3
Thread: Delete MAF
    Nov 2011
    Default Delete MAF
    I'm looking to delete the maf. We are building a twin turbo marine lbz and the maf would cause way too many issues. I know i will have to add an iat sensor, but my concern is maf fuel limiting.
    You might get away with setting the DTC to be still active but no MIL. The ECM will then take the correct action for a failed MAF, but, I am not sure if that would be some form of limp mode.
    Nov 2011
    yeah, so far it has been going into a limp mode. be en trying to get a work around. Just havent figured it out as of yet.
  1. 6.7L Throttle valve delete and egr delete
    By Killerram2500 in forum Cummins 6.7L
    Last Post: November 20th, 2012, 03:41 PM
  2. Dpf delete
    By relentless addiction in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 25th, 2011, 05:41 PM
  3. 5.3 o2 and maf delete????
    By kyl3 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 21st, 2009, 10:00 AM
  4. Dpf delete
    By LIL DAVE in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 9th, 2009, 07:24 AM
  5. Cat delete
    By Automotive Innovations in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: December 27th, 2007, 11:52 PM
