Results 1 to 8 of 8
Thread: PID keep showing unsupported
    Oct 2010
    Default PID keep showing unsupported
    Ok I recently updated to the most up to date software. Now when i tried connecting to my LMM it said unsupported PID and would not log. The pid was iffy so I got rid of it. Now i tried to log again, and i know a PID that 100% works it is saying unsupported and will not log my LMM. Did I miss something now?
    Did you re-program the BBx config (downarrow->Program All)...?
    Can you post your Options.txt file...
    Is your firmware version 2.07.32...?
    Oct 2010
    I did reprogram but I just did it again so i'll try scanning again later and let you know and yes that is the firmware I have. I'll try it again tomorrow and see if it works.
    There is a fault in the LBZ, LMM and LML *.pmm (pid definition files) in the latest release.
    It causes ALL "_M" (i.e. DMA PIDs) to report as unsupported.
    Please download the attached file and unzip it into the folder:
    \Program Files\EFILive\V8\Config (for Win 32 bit systems)
    or
    \Program Files (x86)\EFILive\V8\Config (for Win 64 bit systems)
    Overwrite the existing 3 *.pmm files.
    Oct 2010
    Ok think I just did it correctly. Now what do i do, go to BBX and reprogram?>
    Quote Originally Posted by pavetim View Post
    Yes, once those files have been copied into the correct folder on your hard drive, just click the [Program] button to update them on your device.
    It does that by comparing the file creation dates of the files on your device v's the files you just downloaded. BEcause the files you just downloaded have a later date, they get updated to your device.
    If for some reason that does not work and the files don't get updated, you can manually copy them across using EFILive Explorer.
    Oct 2010
    Well got rid of all my "iffy" pids and tried again to bbl. It now said rpm.pid is unsupported and I know it works. I unplugged and tried again and it works. But now I log desired and actual fuel rail pressure and my desired will read like 4500psi and actual will.read 4534223 psi I know I'm not running 45 million psi lol.
    Can you send me the *.efi log file that shows the rail pressure incorrectly?
    Send to paul@efilive.com
  1. unsupported ecotec pcm
    By Gregs in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: August 24th, 2010, 04:23 PM
  2. LMM Unsupported PID
    By winter200 in forum FlashScan V2 BB Logging
    Last Post: March 14th, 2009, 06:05 AM
  3. Unsupported PID's? Making them "supported"
    By N0DIH in forum General (Petrol, Gas, Ethanol)
    Last Post: October 7th, 2008, 10:40 AM
  4. Unsupported PID
    By JoshH in forum Diesel
    Last Post: June 23rd, 2007, 06:27 PM
