looking for minimum system requirements to run scanner and data log
looking at a new netbook for more battery power
97 2500 ecsb 5.7l/4l80e/4x4 411 pcm /thorley tri-y's/dual super 40's with x (catless)/aem cai/msd 6a and coil/zz4 cam/beehive spring/lm-1
stock sucks
wondering the same myself
Any mordern laptop should work ok... netbooks should be ok but try to opt for the faster Atom cpu and maximized memory.
ya that does help a little but i have seen another thread where they were having problems with some cpu's
stock sucks
If you have FlashScan V2 then you would log via BBL, and then view the log on the netbook, this would remove the burden of logging from the netbook.
Let's see what others say...
My HP laptop recently failed so I am in the market for a new one myself. However as Joe said, these days with the V2 being able to standalone data log and flash tunes I don't even remember the last time I actually used my laptop on my car.
These days most come with 4Gb of memory which is plenty, any of the 'core' series processors should have enough processing power too. What makes a PC fast is a good hard disk or SSD, my old HP laptop had a 5400RPM hard disk which made it feel very slow, if you can afford the extra, get one with an SSD (Solid State Drive).
Ya I have been looking at solid state drives for less power comsumptun and also led screens
Would be nice to know what processors you have had problems with also looking at tables for a dash in my race car as ill be tuning it with efi live
Also just found a 12 cell laptop battery so might just go that route for now
stock sucks
