Results 1 to 10 of 10
Thread: need help flashing
    May 2012
    Default need help flashing
    so iv pulled stock tune now trying to upload a new tune it tells mw that it flashed sucsesfully after i go threw and turn engine off and do the 15 second countdown an alert goes off about something like couldnt save a file and then shows me the file name, i drive the truck and its bone stock iv went threw the process 3 times does anyone know what i am doing wrong? please help!!!!
    Are you using V7.5 or V8? What type of ECM or TCM are you trying to flash?
    May 2012
    i was using the v7 software i guess since its a v8 compressed tune file should i use the v8? another question is there any way i can actually tune with the v8 software and the ecm is the ls1b gen 3 98 threw 08
    Are you logged into your Windows with administrator rights...?
    What V7 and V8 software build versions do you have...?
    What V2 firmware version...?
    Correct, from V7 save the file as .ctz.
    V7 is for editing the tune file; V8 is for reading/flashing.
    May 2012
    my windows with administrator rights??? idk
    version 8.2.1 build 200 and v7.5
    and what u mean save the file as .ctz.
    May 2012
    sorry i hope u guys can bare with me this is literally my first flash i have performed
    File->Save Tuning File As and select .ctz as the file type (if the file is not already of that type).
    When V7 or V8 says it can't save a file, it means you're logged into Windows with insufficient privileges/rights, so Windows won't allow EFILive (being run by you the logged-in user) write the license backup file to your PC's hard disk.
    May 2012
    Hey joecar thanks for ur advice i opened up file in the v7 saved it and flashed with v8 worked out real well thanks again
    Cool, glad to hear it worked
  1. Flashing tunes
    By AIRBORNE in forum General
    Last Post: January 16th, 2012, 06:26 AM
  2. ? on flashing tune
    By Dave T in forum General
    Last Post: August 14th, 2011, 02:48 AM
  3. Getting error when flashing
    By minytrker in forum General
    Last Post: February 20th, 2011, 07:01 PM
  4. Flashing different OS?
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 3rd, 2010, 10:00 AM
  5. re-flashing
    By s10mods in forum General (Petrol, Gas, Ethanol)
    Last Post: September 18th, 2007, 10:39 PM
