Results 1 to 7 of 7
Thread: Can someone overlook my tune
    Senior Member pdasterly's Avatar
    Oct 2007
    Default Can someone overlook my tune
    2004 gto a4, 224/224 cam
    gto nick newtech.tun
    1998 Camaro Z28, forged ls2 sts turbo GtsT76, fmic
    1999 Firebird, forged ls1 procharger p1sc ls9 cam fmic
    1981 El Camino, 5.3 LSX carb, msd 6010
    2011 2SS
    Is your tuner ok with you posting your tune here...?
    Lifetime Member BLK02WS6's Avatar
    Jun 2005
    There are things I would do different, but the only real "problem" I see is that your high and low octane tables are the same - wouldn't recommend that...
    GM EFI Tuner
    02 WS6 9.41 @ 143 MPH 3675#, drag radials, pump gas, through the mufflers - sold
    Lifetime Member smslyguy's Avatar
    Oct 2008
    Quote Originally Posted by BLK02WS6 View Post
    How can you get away from that when you run c.l.s.d tune?
    2001 camaro z28 ss vert with factory slp upgrades, Hooker long tubes, 3"y-pipe to a 4" muffler, ,airlid,s.s.r.a. ,t.c.bypass,descreened m.a.f. 232/234 .595,.598 +2 comp cam with ported and polished stock heads with .650 lift dual springs and a bowl grind. tuned with EFI Live. All combined to achieve 29 m.p.g. and 399 r.w.h.p. with 384 lbs of torque. sold...
    Now own a 2015 1LE camaro
    Jun 2005
    You didn't provide any details of what you are doing here - do you have it in CLSD because you are you tuning the VE now? Or are you planning on leaving it in CLSD? If you are leaving it that way, a custom operating system is the way to do it...
    GM EFI Tuner
    Oct 2008
    Yes I am and have been running c.l.s.d. that's one draw back from what I can tell is that while running c.l.s.d. it doesn't allow u to run a low and high spark table.. I'm not to femilar with costing operating systems, can u run c.l. in a costom operating system??
    Yes, you can run CL in a COS...
    COS and GM OS can run in any of: CLMAF, OLMAF, CLSD, OLSD.
    The COS does everything the GM OS does, with a few added features:
    - in SD it retains the HO/LO adaptive spark,
    - the OLFA table is now RPM x MAP (instead of ECT x MAP),
    - a few other things (tables for boost, nitrous, TPVE) which you don't have to use.
  1. Good N/A Tune but...Going Supercharged I could use advice on a base tune
    By tatasta in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: April 6th, 2011, 09:16 PM
  2. Replies: 5
    Last Post: August 5th, 2008, 02:35 PM
  3. What else can I tune without scanning or black boxen it? Tune history inside.
    By Round Rock TJ in forum General (Petrol, Gas, Ethanol)
    Last Post: May 3rd, 2007, 02:27 AM
  4. Convince me to change to a 2bar tune...709rwhp through an EFI maf tune.
    By onfire in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 16th, 2006, 12:04 PM
