Results 1 to 9 of 9
Thread: How many RPM is safe for a genIII truck engine?
    Senior Member Wasted Income's Avatar
    Dec 2005
    Default How many RPM is safe for a genIII truck engine?
    My brother wants me to bump up the rev limiter in his 5.3L 1999 Sierra to 6500 rpm. Can the 5.3 spin 6500 on occasion (for a second) without coming unglued??
    Thanks guys,
    Jeff
    2005 Silverado Duramax LLY - EFI Live Tuned
    1969 Chevrolet C-10 Pickup - Turbocharged 5.3L/4L80E - EFI Live Tuned
    1975 Avenger Jet Boat - 6.0L/Berkley pump - EFI Live tune in progress
    Jeff,
    The only thing that limits the motors rpm limits is the valvetrain. The stock pushrods should be replace and a good set of valve springs with Ti retainers and locks. If you are going to bump the REV limiter more then likely it will see that rpm more then a few times!
    No sense spinning it up to to much as there isn't too much power up there with the stock camshaft.
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Aug 2004
    It will valve float that high. 5800 is about max. I wouldnt want to go any higher.
    Jan 2005
    The lower end will probably handle 6500 with no problems, but the valvetrain is questionable, because the stock springs probably aren't up to the task-- especially if the engine has a lot of miles on it. A bigger question is "Why". Assuming a stock cam, it's pretty much all done by 5500 rpm, so why push rpm to the point where horsepower really drops off? I think a bump to the 5800-6000 range is a better choice.
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
    Lifetime Member MN C5's Avatar
    Mar 2005
    Thats my experience as well 5800 for shift points max...
    Dec 2005
    Great, that's exactly the info I was looking for!!
    Thanks guys!
    Quote Originally Posted by dfe1
    Hey! Thats what I said!
    1-954-703-5560
    Jan 2005
    Quote Originally Posted by Redline Motorsports
    What can I say great minds, etc. When I started typing my reply, no one else had answered. But then I got side-tracked and when I finally got back to it, you had already replied. Didn't mean to step on your toes.
    678/344-1590
    Oh no bad intent here!
    I figured we must have past threads! At least he got the same answer twice!
    1-954-703-5560
  1. Is the engine pretty safe as long as you have no knock?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 1st, 2009, 01:36 PM
  2. Camaro tune to control truck engine?
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: December 4th, 2007, 05:36 PM
  3. 6.0 L Truck engine fan control pins
    By JohnL in forum Gen IV V8 Specific
    Last Post: September 4th, 2007, 12:33 AM
  4. Engine/transmission programming dilemma for GM truck
    By PSWired in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 6th, 2005, 11:53 PM
  5. Engine/transmission programming dilemma for GM truck
    By PSWired in forum General (Petrol, Gas, Ethanol)
