I just bought an 06 trailblazer ss awd that is totally stock. I believe it is the e40 ecm. Does anybody have a tune that will wake this truck up? I would like to find a tune that disables the torque management or tell me how to do it.
I doubt anyone will just give you a tune, most of us that tune full time make money by selling tunes. If you make an effort at learning and post up your tune and log file you will get plenty of help if your not looking at buying a tune.
Yes it does have the E40 (hate them) the biggest and quickest thing you can do is to disable tourque management. Its very easy; you just go to tourque-limits-perameters, and then set 515,516&517 to "DISABLE". This is not the safest thing to do, in fact its known as Kill Mode to some of us because your pcm is not going to limit the powere going to things that could potentually break like the tranny, transfer case, front and rear diff ect... that being said I am running my 06 TBSS like this and have had no problem.
No TM + AWD in a TBSS = blown trans. No a question of if, but when.
I run 50% TM in my 08, Id start with that and go from there. In the TCM, look for the TM folder and reduce the cells by 50%. I also have my BTM disabled, but its only disabled with TC/ST are disabled as well.
