Whats up guys,
I was diagnosing a coolong fan issue on a 97 f body lt1. I used bidir to command the fans on and it did not work. so I commanded the low speed fan and the a.i.r. pump came on. After verifiing that the problem was the relay the old way, I started checking the other headings in bidir. come to find out that the closed loop heading is the one commanding the fans on/off. as well as the high fan commandes the fuel pump. are you aware of this? Is there a fix?
Thanks for the great support. let me know,
madprof01
