Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 63
Thread: Advice for firest time procharger tuner
  1. #21
    In the FAST 65 spreadsheet the Minimum Injector Pulsewidth goes into B4003 Minimum Injector Pulsewidth, but again the axis doesn't line up.
  2. #22
    ( that FAST spreadsheet is hard to use )
  3. #23
    make B3616 PE Enable a little easier to trigger PE (set it to 60% below 4000 and 30% above 4000);
    make the 0-3200 rows of B3647 the same as 3600 and up (i.e. copy/paste lower part to upper part);
    and then make B3618 the same as the 100kPa column of B3647.
  4. #24
    Fix the out-of-range cells in A0009, A0012, A0013
    [ A0009: reduce the ve value; A0012,13: set it to max-1 ]
  5. #25
    B5913/B5914 HO/LO Spark Timing tables will need to be reduced.
  6. #26
    Quote Originally Posted by andysc3 View Post
    For A0010, Boost timing table, Where does it subtract the timing from. When I look at the high octane timing table it goes to 1.20 Grams/Cylinder. Right now Im at about .85 g/cyl. With boost wont that take me past that point? And since the procharger makes boost with RPMs do I want A0010 to be about the same # across the board? Im currently running 31* max at my shift point, if I set it to 20 that will make my final timing 31, correct? and I am running 22* at the lowest so that would be 2*. Does that sound right? Thanks for the help
    Andy
    A0010 subtracts from whatever the PCM computes as spark timing...
    when MAP goes above 105 kPa, when 1.20 g/cyl is exceeded, the PCM uses the timing value from that final column (1.20 g/cyl), and A0010 then subtract from that value.
    As MAP increases above 105 kPa my understanding is you want to subtract more timing.
  7. #27
    Jan 2012
    OK, I set the PE to trigger a little earlier than what you suggested. The 3700 rpm torque converter is rather loose and Im at about 3k rpm just to keep up with traffic. I adjusted 3647 and 3618. What is a safe AFR for boost. Its set to 10.5 for now. How much do I need to reduce the timing tables? As for the injector data. Its a good thing I have the next two days off work lol.
    2011 Cadillac Escalade ESV. BTR 218/224 .553/.553 110LSA. Built 6L80 with 278mm Circle D 2800 stall converter.
  8. #28
    For significant load at boost you would have to get the AFR to something like 11.4-11.8 or so...
    10.5 seems too rich to me, but let's get more opinions.
  9. #29
    Jan 2012
    OK, Id rather have it alittle rich at first vs too lean and melt a piston lol. For the missing values in B4005, can I avg the cells on each side and put it there? And the same for B4003?
  10. #30
    Jan 2012
    as far as A0009 being out of range, all the cells are in range so Im not sure why thats coming up.
  1. 2010 ss + procharger
    By tokymon in forum Gen IV V8 Specific
    Last Post: April 9th, 2010, 09:55 AM
  2. 6.0 truck with procharger
    By DKD in forum Gen III V8 Specific
    Last Post: July 24th, 2008, 11:01 AM
  3. Tune for a procharger?
    By ForcefeedWS6 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: March 28th, 2008, 08:16 AM
  4. Procharger Question
    By gto4evr in forum General (Petrol, Gas, Ethanol)
    Last Post: September 26th, 2006, 02:48 PM
  5. ?procharger on alchol
    By 2002 camaro in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 31st, 2006, 06:56 PM
