The latest EFILive software update is available here: http://www.efilive.com/index.php?opt...=48&Itemid=133
Hello Paul,
Builds 211 / 202 addressed the LS1-B issue that had presented itself with builds 210/ 201 - works great now.
Thank you for the very quick roll out of the patch / next build version of the software.
Taz
Was not able to flash an LLY or LB7 this morning without taking the normal fuses out and unselecting high speed. just kept saying bootloader rejected, reason:no reply. this patch fixed it. thanks blacky. works good now.
2015 3500HD crew cab long bed, 6" fabtech, slightly tuned, emissions intact.
2005 dmax ccsb, EFI live tuned DSP 5 Full built motor, S471 billet single, More better built trans this time. and lots of other things.
1984 CJ7 powered by a 2000 LS1. 4L60E.
2012 Jetta TDI 6 speed manual, (yes the dirty the bastard haha)
2003 Jetta TDI,
1986 K10 LQ4/4L80E
Thanks Paul the problem with LS1B solved with this patch
EFILive Tuner
Any chances to see the T76 calz files on the auto update
thanks
Which not much explanation of what the problem is I can't really offer much help, but...
Have you tried installing the old USB drivers using: Start->All Programs->EFILive->V8->EFILive USB Manager
FYI
V7 works better with the older drivers.
V8 works with both drivers, but may "blue screen" with the old drivers when multiple FTDI USB devices are connected.
I could flash them until this last update. V7.5 will give the boot loader error like I was getting with ls1a before update. I can flash ls1b only with v8. I haven't tried ls1a since update but have one this week to do.
