Page 10 of 10 FirstFirst ... 8910
Results 91 to 92 of 92
Thread: EFILive V8.2.1.202 and V7.5.7.211 June 22 Update is Available
  1. #91
    Mar 2011
    with windows 7 and 8 on the present build and release I can not do a full flash on a lb7 it acts like it flashes it but is done in 2 seconds, a cal flash does work..
    Joe Kupferschmid
    Daves Diesel Angola
    www.angoladavesdiesel.com
    Diesel and gas tuning
    Personal Vehicles tunes with efi 06LBZ, 05lly, 2002 Z28, 2004 Gto
  2. #92
    Quote Originally Posted by House View Post
    A full flash has the option to change the seed/key (i.e. to lock the controller) during the full-flash. A cal-flash does not have that option.
    Regardless of whether you select the "lock during full flash" option or not, the software will attempt to save the actual seed/key pair that is flashed into the controller during the full-flash.
    The software attempts to save the seed/key pair in the file:
    \Program Files\EFILive\V7.5\PCMLocks.ini (win 32 bit)
    or
    \Program Files (x86)\EFILive\V7.5\PCMLocks.ini (win 64 bit)
    For security purposes, by default Win7 and Win8 operating systems prevent applications from altering files in the Program Files folder or subfolders.
    To allow V7 to complete the full flash you need to tell Windows that its ok for you to update files in that folder.
    On windows 7 do this (I'm not sure how to do this same change on Win8):
    Right click on the \Program Files\EFILive\V7.5 folder name.
    Go to properties>security tab
    Click [Edit] (if you are not running as administrator and UAC is active you will need to provide the admin password at this point).
    Click [Add]
    Type your Windows User Name and click [Check Names], it should show your computer name and user name like this COMPUTER\user
    Click OK
    Make sure the newly added username is selected and check the [Full Control] check-box.
    Click OK
    You should now have full permission on that folder which will allow the EFILive software to write to the PCMLocks.ini file.
  1. Public Release Update June 06, 2011
    Last Post: June 20th, 2011, 07:12 AM
  2. BBL installer update: June 12, 2008
    By Blacky in forum FlashScan V2 BB Logging
    Last Post: June 22nd, 2008, 07:57 AM
  3. BBL installer update: June 12, 2008
    By Chevy366 in forum FlashScan V2 BB Logging
    Last Post: June 13th, 2008, 10:37 AM
  4. June V2 update
    By jfpilla in forum E37, E38 & E67 PFI ECM's
    Last Post: August 13th, 2007, 11:09 AM
