Results 1 to 5 of 5
Thread: Vortec only logging at 2 frames/sec w/ laptop hooked up. Also dash 3-4 mph off log ?
    May 2012
    Default Vortec only logging at 2 frames/sec w/ laptop hooked up. Also dash 3-4 mph off log ?
    2 newbie questions. I am logging a 1999 old body style classic Chevy C1500, 5.7 vortec, with a Flashscan V2.
    1. Using the laptop to log through the V2 using the 7.5 scanning software, I am only getting 2 frames/sec logging in my saved data log. This is slower than the 10 frames/sec my old TPI-era obd1 stuff logs at....why is it so slow? I hope I can log at least 10 frames/sec, 2 is useless. Is there a max # of PIDs I can select to log at a decent speed, and if so, how many?
    2. My dash speedo reads 3-4 mph faster than the datalog...I corrected the tune for tire size and the ecm logged speed is accurate but the dash reads 3-4 mph fast. Any idea other than my dash is defective?
    Thanks!!! I am pretty computer literate but tuning and logging is always a steep learning curve for me.
    Steve
    What V7/V8 build versions, and what V2 firmware...?
    May 2012
    V2 Firmware 2.07.27 Date Apr. 20, 2012
    V7.5.7 build 204
    V8 won't show me its build info under "help", says not available yet
    I just bought this stuff about a month ago
    Hi Bondo,
    Ok, do this:
    - download/install both V7 and V8 from here (you want the "full install" files: http://forum.efilive.com/showthread....e-is-Available
    - flash firmware 2.07.35 into your V2;
    - program your BBx config to your V2 ("Program All").
    After that, try logging again and let me know if it shows the same slowness or if it fixed up.
    Quote Originally Posted by Bondo Special View Post
    Check out the data logging speed section in the Scan Tool manual in page 186. You can get to the Scan Tool manual using the Scan Tool Help->Help menu.
    As for the speedo discrepancy, I'm sorry I don't have an answer for that. That discrepancy may be built into the gauge or the cluster.
  1. Need to somehow power my laptop for logging
    By Whipped383 in forum General
    Last Post: May 5th, 2011, 05:08 PM
  2. Using inverter for laptop + FS V2 with serial logging
    By Dopey in forum FlashScan V2 BB Logging
    Last Post: September 10th, 2008, 08:37 AM
  3. LC1 Hooked up First Log for AUTO VE
    By Kurtomac in forum Gen III V8 Specific
    Last Post: August 25th, 2008, 11:08 PM
  4. Dash error codes while logging
    By alian in forum Black Box Logging
    Last Post: August 18th, 2008, 07:27 PM
  5. Number of WOT frames vary for BB logging, why?
    By kp in forum General (Petrol, Gas, Ethanol)
    Last Post: July 24th, 2006, 12:47 PM
