Results 1 to 5 of 5
Thread: help have small lope on one tune only in dsp5
    Apr 2008
    Default help have small lope on one tune only in dsp5
    here is a couple of logs from dsp5 only happens on one tune
    and i happens to be a my tow tune
    Log_gorg gm_0007.efiLog_gorg gm_0008.efiLog_gorg gm_0009.efiLog_gorg gm_0010.efiLog_gorg gm_0002.efi
    hoping some one has some input on how to smooth it out
    the lope is anoying
    stock sucks
    Jan 2006
    You will have to post the tun file, logs only prove that you have the lope. The problem is in the tune.
    Custom Tuning Services
    Feb 2007
    Check the pulse width in the idle areas of the pulse width table in the tune that is loping. Make sure it is stock or close to it.
    Jun 2011
    throttle torque table could also cause the lope
    Apr 2011
    What Josh said X2! Just had this issue with mine.
    Matt
    '06LLY, 5" MagnaFlow Turbo-Back Exhaust, EGR Blocker, K&N Filter...
  1. Replies: 4
    Last Post: May 20th, 2012, 12:21 AM
  2. LB7 Lope Tune
    By Hoytmax Diesel in forum Duramax LB7
    Last Post: May 7th, 2012, 02:04 PM
  3. LB7 Lope tune strange issue
    By LBZoom in forum Duramax LB7
    Last Post: January 4th, 2012, 11:39 AM
  4. LBZ/LMM Lope tune
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 12th, 2011, 02:55 PM
  5. Lope tune!
    By jcbduramax in forum General (Diesel)
    Last Post: July 8th, 2010, 01:46 AM
