Thread: 97 cav OS help??
    Aug 2006
    Default 97 cav OS help??
    hey guys i am trying to help a guy at work with his 97 cav. 4cyl manual trans, he is doing very well dirt track racing it but wants to get rid of the rev limiter, i read the pcm but an error message came up? the OS is 16259657, any help would be great!!!
    Unrecognized PCM... let me ask about that.
    May 2010
    They should be able to add this os in.
    1997 S10, 06 trailblazer SS LS2 swap, 4L70E trans, 76mm turbo. Factory ZQ8 suspension. 3.08, G80 w/a zexel. With a 0411 swap.
    May 2010
    Supposedly a 1997 tune from a cavelier is not supported. Efilive only supports 1998-2002. What about swapping in a 1998 cavelier ecm? edit 1997-2002 is supported.
    Aug 2006
    any luck yet, he is racing saturday and needs this done if i can get some help guys. thank you guys for the help so far
  1. I have a .tun from an '02 cav Z24
    By vortecfcar in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: October 7th, 2007, 04:01 AM
