Results 1 to 6 of 6
Thread: 97 cav OS help??
    Aug 2006
    Default 97 cav OS help??
    hey guys i am trying to help a guy at work with his 97 cav. 4cyl manual trans, he is doing very well dirt track racing it but wants to get rid of the rev limiter, i read the pcm but an error message came up? the OS is 16259657, any help would be great!!!
    Unrecognized PCM... let me ask about that.
    May 2010
    Supposedly a 1997 tune from a cavelier is not supported. Efilive only supports 1998-2002. What about swapping in a 1998 cavelier ecm? edit 1997-2002 is supported.
    1997 S10, 06 trailblazer SS LS2 swap, 4L70E trans, 76mm turbo. Factory ZQ8 suspension. 3.08, G80 w/a zexel. With a 0411 swap.
    May 2010
    They should be able to add this os in.
    Aug 2006
    any luck yet, he is racing saturday and needs this done if i can get some help guys. thank you guys for the help so far
  1. I have a .tun from an '02 cav Z24
    By vortecfcar in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: October 7th, 2007, 05:01 AM
