Results 1 to 9 of 9
Thread: Wont shift at wot
    May 2012
    Default Wont shift at wot
    2008 Silverado 5.3L 4 speeds,, now it has a 6.2L engine. it runs pretty good, shift ok under normal conditions but at WOT it will pass the 6000 RPMS and it would not shift to 2nd gear, i need to release the accelerator to allow the trans to shift to 2nd gear.. those are the current tunes on the truck..
    what do i need to look into?
    Oct 2011
    When mine did this the transmission output speed was off even though the dash read correctly.
    May 2012
    Any help please???
    I'll look at the files later today...
    May 2012
    thanks
    I'm running a day behind...
    I take it that the shift pattern used is "Normal"...?
    D1101 Normal WOT 1->2: 47 mph ---> what is that in rpm...?
    Try this (assuming Normal shift pattern):
    - lower D1101 to say 40 mph;
    - lower D1061 to say 35 mph;
    - lower D1021 to 5500 rpm;
    retest with those to see if you get the WOT 1->2 shift; and then incrementally adjust them back up until your see the WOT 1->2 shift at the desired rpm
    ( always keep D1061 below D1101, and likewise for other table pairs ).
    May 2012
    Ill try it tomorrow, thank you very much i really apreciate it, im on the learning curve rigth now, i do the best i can because i can read english 100 %, speak it like 60 %, understand it if i read it 100 %,,, im from mexico and i think im the only one that has efilive here where im from. i have a shop, custom swap, mostly using LS engines, thats why im using efilive rightnow, and i love it
    No worries cool.
    Make sure your VE and MAF are correct so that the PCM can calculate engine torque correctly... the PCM uses engine torque to calculate the transmission line pressure;
    keep an eye on the pids TRQENG and TFMPRS, make sure these go up sufficiently as engine load goes up (to prevent internal slipping in transmission).
  1. rpm cut off comes up before the 2>3 shift , wont shift
    By Eric in forum Gen III V8 Specific
    Last Post: June 6th, 2011, 09:58 AM
  2. wont shift to 5th under WOT
    By pullincrazy88 in forum Allison 5 & 6 Speed
    Last Post: April 29th, 2009, 09:09 AM
  3. 4l60e wont shift
    By chris98z71 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 26th, 2009, 07:26 AM
  4. Truck wont shift and getting a U0100
    By heathgu in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 20th, 2007, 01:39 PM
  5. A4 Corvette w/3.90s wont shift at WOT
    By Chuck CoW in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 17th, 2006, 06:20 AM
