Results 1 to 6 of 6
Thread: EGR and Timing
    Junior Member kaiserbailey's Avatar
    Jun 2012
    Default EGR and Timing
    I'm pretty sure EGR has the effect of retarding timing, so when you delete it should you lower timing around idle a little bit?
    Stock 5.9 is in the -2* to -4* range, stock 6.7 is +1* (BTDC). I would think, after you delete EGR +1* would be a little much since the 5.9 is -3.
    Senior Member Krazeeun's Avatar
    Jan 2012
    I've found that 40% on the calculator at idle areas makes it purr like a kitten... FWIW
    "I will not keep calm..." -Ryan Milliken
    Hardway Performance
    Jan 2012
    Could this be cause for the white puff of smoke I get at startup?
    07.5 Mega stock
    00' EX-Cab MFI
    Jan 2012
    just looked at one of my maps, both of my truck idle around 1.4*
    Hardway Performance
    Jun 2012
    Quote Originally Posted by Robs24vCTD View Post
    I doubt it.
    Quote Originally Posted by Krazeeun View Post
    Cool, would it help spool the charger if I backed it down to 0* or does it just like to run around 1* better?
    Lifetime Member 06redram's Avatar
    Jan 2011
    The lower the timing the hotter it gets the quicker the the turbo will lite. That should take same of the smoke out. For white smoke, sound like you need to adjust you pilot + or - a little bit at a time or you are not getting enough fuel like ( duration ) in pilot or main at start up. I hope this will help you sense I can't not see you tune or log to the spot the error that's causing your ill effect
  1. Disable EGR?
    By shadyst in forum Gen III V8 Specific
    Last Post: July 2nd, 2009, 03:46 PM
  2. EGR timing
    Last Post: September 11th, 2008, 03:58 PM
  3. EGR on or off?
    By JODAGR in forum Gen IV V8 Specific
    Last Post: January 5th, 2007, 01:52 AM
  4. 00 SS with no EGR
    By trudynosports in forum General (Petrol, Gas, Ethanol)
    Last Post: June 10th, 2005, 01:53 AM
