Thread: LMM rail pressure
    Apr 2006
    Default LMM rail pressure
    I am unable to raise the desired rail pressure on my LMM. I have changed all the tables that are associated. I have also tried changing the rail pressure at idle with no luck....... Could you guys please look into these issues,
    Apr 2006
    #@#$$@ help please!!!!! $^&@!*#(
    If it's your own tune not a"purchased" tune post it and some logs and I'm sure people with help.
    04 LB7
    2010 LMM
    2015 LML
    Feb 2007
    What OS?
    Apr 2006
    8594 OS. It doesn't seem to matter what I change, desired rail pressure in the tune WILL NOT match the desired rail pressure on the scan tool if it is different value than the tune came from the factory with. I can load a tune with every rail pressure table set to 180MPA across the board, and fire the truck up check it with the scan tool and it's still 30MPA desired. Same goes for WOT, 180MPA is MAX. I've checked over every parameter/limiter and it just cannot be raised.
    Nov 2012
    I have the same problem with my 08 LMM. It is the 8594 OS as well.
  1. Rail Pressure
    By mstordahl in forum Cummins 5.9L
    Last Post: June 11th, 2012, 11:27 PM
  2. Rail Pressure tuning help?
    By AdamRRT in forum Cummins 5.9L
    Last Post: October 24th, 2011, 01:00 PM
  3. 6.7L rail pressure sensor in a 5.9?
    By skneeland in forum Cummins 5.9L
    Last Post: September 15th, 2011, 05:35 AM
  4. fuel rail pressure
    By drdarthinvader in forum General (Petrol, Gas, Ethanol)
    Last Post: January 8th, 2009, 07:17 PM
  5. Fuel Rail Pressure
    By Dave Lewis in forum Duramax LB7
    Last Post: July 30th, 2006, 02:54 PM
