Main volumetric efficiency table.
Based on Engine RPM and manifold absolute pressure (MAP).
The values in this table represent the efficiency of the engine's ability to fill the cylinders with air.
It is used to predict the volume of air entering each cylinder under varying conditions.
So what is considered good 50,60, 100?
Does 100% mean that is predicted the amount perfectly? Should I shoot for something like 90% for some area to work with?
If its showing 100%+, like on my s/c gto, where its shown 150+ when running at the track is that bad? I assume so since the ltft were way positive?
Just trying to understand a little better.
thx
