Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Who's using dyno integration
    Lifetime Member limited cv8r's Avatar
    May 2005
    Default Who's using dyno integration
    Just wondering who's using dyno integration with V2,what do you think of it and how are you using it to improve / help your tuning. I may have the opertunity to use a mainline dyno soon and just looking for tips on getting the most out of this feature.
    It's probably going to be a silent thread, only because I know the workshops here in Australia that do use it with their Mainline's probably aren't even registered on the forum.
    Lifetime Member JezzaB's Avatar
    Nov 2006
    I use it a bit here and there (more so when I was testing it for Andrew/Todd, etc) Dont think they ever got around to putting in the inertia correction in though and other PIDs
    But i mainly run on our Mainline a TechEdge wideband and Andrew has modified the dyno software so that I can get serial into the dyno and I use my other serial out to send to my V2. So the data is EXACTLY the same.
    I wish I could integrate it with our chassis dyno....
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    What make is your chassis dyno Howard?
    Its a Land & Sea Unit
    http://www.land-and-sea.com/chassis-...assis-dyno.htm
    I like it because you can get into the software and configure things like EFIL.
    There engineers are very knowledgable and we've talked to them about this. Just need to get you guys together.
    Howard
    1-954-703-5560
    Quote Originally Posted by Redline Motorsports View Post
    If you look in the V8 folder on your PC, under 'Documents' there is a pdf called "EFILive FlashScan Serial Protocol", that pretty much covers everything they need to know. Beyond that they should contact Paul.
    May 2005
    Could somebody please post up or PM me the proceedure/setup to use efilive V2 with a mainline dyno.
    Jul 2003
    I wish I could use it with my DynoJet.
    The best integration has always been the wideband integration!!! But if I had a dyno integration, it would be golden.
    Quote Originally Posted by limited cv8r View Post
    Contact Andrew at Mainline for the settings in their software. For V2, just set the serial port to Dyno.
    Quote Originally Posted by Highlander View Post
    Can that dyno output serial data?
  1. Need data for dyno integration.....
    By Redline Motorsports in forum General
    Last Post: January 16th, 2017, 04:44 PM
  2. Dyno software integration
    By samgm2 in forum FlashScan V2
    Last Post: September 3rd, 2011, 10:51 PM
  3. Dyno integration complete
    By GMPX in forum General
    Last Post: October 24th, 2009, 11:41 PM
  4. Dyno Integration?
    By Highlander in forum FlashScan V2
    Last Post: June 15th, 2008, 02:35 PM
  5. Wideband/dyno integration
    By Blacky in forum EFILive V6
    Last Post: May 24th, 2004, 10:07 AM
