Results 1 to 5 of 5
Thread: LB7 - GM.FRPACT PID not linking
    Jun 2011
    Default LB7 - GM.FRPACT PID not linking
    I'm not sure if this is an LB7 only issue but at the moment that's what I'm working on and there is an issue. The issue I'm having, the GM.FRPACT pid is being logged ok but it's not linking from the scan tool to the tune tool. Could someone please explain the fix to me?
    Jun 2011
    Everything looks ok in the cal link notepad. What am I missing?
    Jun 2011
    Got it!
    How did you get it going...?
    Are the scantool units for that pid the same as the tunetool table's axis pids...?
    Jun 2011
    I was using the same pid list that I had so many times before. I had just updated to the latest version software and some how the FRPACT pid got switched to imperial. Simple fix once I realised what it was.
  1. 02 LB7 balance rate PID's gone from list?
    By haulinit in forum Duramax LB7
    Last Post: June 11th, 2012, 11:37 AM
  2. Autocal linking
    By bballer182 in forum AutoCal
    Last Post: August 21st, 2010, 04:42 AM
  3. Linking discrepency
    By Nox in forum General (Petrol, Gas, Ethanol)
    Last Post: April 8th, 2005, 05:10 PM
