Results 1 to 8 of 8
Thread: 20 Degree timing offset still there?
    Lifetime Member LBZoom's Avatar
    Jun 2008
    Default 20 Degree timing offset still there?
    Hey guys,
    Having a couple issues, unfortunatley the customer can't get me a log until he gets back from his vacation....
    Flashing auto trans trucks and they run fine..... flashing manual trucks I'm having issues it seems...
    The one in question here has trouble cranking and misses while driving, which makes me wonder if the 20 deg offset is still active somehow? I was pretty sure it was corrected last update, I did however use the timing calculator in the software, may have done it wrong though.
    Thanks!
    Peace Through Torque
    www.PunisherPerformance.com
    Since about Sep-2011 the timing offset was corrected, so many versions ago.
    Jun 2008
    That's what I was thinking, have to dig deeper now.... thanks!
    Mar 2009
    Did you start with a clean stock file? I know that if a Cummins has a tuner on it before you run EFIlive it doesn't start out clean. The Cummins computers will hold some old tuners information.
    2002 Chevy Duramax with a few supporting mods.
    Jun 2008
    Yep started with a clean file from the Internet, both trucks are 5.9 2006, and both have had Smarty in the past.
    Both trucks barely want to start and they load up with fuel and then cut out and even die. Same file on an auto runs fine?!
    Mar 2009
    How about trying to change to a different OS.
    Jun 2008
    Well I thought about that, one of the guys had been making some basic tunes himself, he sent me the base stock file that he's been using and it was the same OS as the one I sent him.... Makes me think it HAS to be the tune, anyone have an email I can send the tune file to look over?
    Junior Member dodgeram082500's Avatar
    Nov 2009
    does the truck actually start or just it just sputter and die
  1. 160 or 187 degree thermostat a new twist, old test and a SURPRISE!!!
    By 98 tigershark in forum General (Petrol, Gas, Ethanol)
    Last Post: July 24th, 2009, 03:46 PM
  2. b0304?? baro offset...
    By ls698ta in forum Gen III V8 Specific
    Last Post: March 20th, 2008, 08:12 PM
  3. 160 degree t-stat
    By Spdfrk1990 in forum Gen III V8 Specific
    Last Post: June 19th, 2007, 05:00 AM
  4. 160 degree Thermostat
    Last Post: April 29th, 2006, 07:20 AM
