A little background first. This is a gen6 bbc 460ci with 50# injectors and running a cos3 OS with 2 bar map sensor getting ready for whipple to go back on.
my issue is while data loging my VE table under hard heavy throttle/load (when you would expect PE to kick in) the commanded AFR goes INSANELY too rich and kills the motor. I have tried everything i can think of to stop this issue and I need an outside look into this. I will post a log of this and the current tune.
any ideas or help is GREATLY appreciated....
Robby
and PS if I load in a 1 bar non custom OS tune and use a 1 bar Map sensor this issue is not present.
