Results 1 to 10 of 11
Thread: EFI will not pull tune lock issue? can i reflash with stock tune file..
    If it's an LMM then the lock will not stop it being flashed over, but it will indeed stop it being read.
    With a TechII or EFILive you should be able to flash over the top with another tune, however with HPTuners probably not because their system checks the VIN against the ECM OS and won't proceed if it doesn't get a match, in the case of a EFILive DSP5 OS they won't recognise it.
    Also, obviously if you relfash the ECM with a stock tune then you'll loose the DSP functions.
    Jul 2012
    well should i just let gm reflash it first try before my buddy does a reflash and changes the vin with efi? im okay with loosing function of dsp5 cause i have no clue what is what and my over heat issue while towing although may not be tune related but may being i have no clue what stock is.. thoughts?
  1. ANOTHER LLY Problem, (cant pull stock file)
    By TRUBBS in forum Duramax LLY
    Last Post: June 3rd, 2012, 02:53 PM
  2. Need stock tune file of OS 12593058
    By Gregs in forum Gen III V8 Specific
    Last Post: March 21st, 2012, 05:55 AM
  3. Need a stock 6.7 tune file please
    By LBZoom in forum Cummins 6.7L
    Last Post: January 22nd, 2012, 03:25 AM
  4. stock tune file?
    By THEFERMANATOR in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 22nd, 2011, 05:54 PM
  5. cant pull the stock file
    By saltflat in forum Vortec V6/V8 Specific
    Last Post: June 2nd, 2009, 02:10 PM
