Page 1 of 13 12311 ... LastLast
Results 1 to 10 of 126
Thread: truck isnt going to full mm command or timing?????
    Senior Member DieselMafialb7's Avatar
    May 2012
    Default truck isnt going to full mm command or timing?????
    got a 06 5.9 wont go past 120mm or past 6-8* timing i cant figure it out ? any hints tables i may have missed? scan tool showed it was stopping anywere from 115-123mm truck has a built 48re and exhaust any help is appreciated
    Nov 2010
    Under limiters...go through all the tables and max them out, drive it and see if that changes your issue.
    If so then do most of your limiting in the torque and boost tables.
    May 2012
    maxing the tq table makes the truck shift stupid but i can try the rest
    Nov 2010
    You started with a clean tune right??
    May 2012
    yes totally stock truck
    Nov 2010
    Can you define "Shifting Stupid" slightly more??
    May 2012
    it made it shuttle shift 1-2 i had the tq tables pretty high in lower rpms ect and soon as i rescaled it that went away trans is like 1800 miles old
    Nov 2010
    Sounds like you'll need to adjust your TTVA tables to solve the shuttle shift.
    May 2012
    How so by rasing them up or down?
    Nov 2010
    Adjust the lower values up a few % at a time till the SS is cleared.
  1. Full flash gone wrong truck won't start !!!!
    By Collins in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 15th, 2012, 10:18 AM
  2. Replies: 2
    Last Post: January 20th, 2012, 02:35 AM
  3. How many MM3's can you command?
    By LBZoom in forum Duramax LB7
    Last Post: February 2nd, 2010, 12:15 PM
  4. What AFR do you want to command at Idle?
    By Loudmouth LS1 in forum Gen III V8 Specific
    Last Post: January 19th, 2007, 02:06 PM
  5. command vs actual a/f
    Last Post: June 9th, 2006, 01:50 AM
