Page 13 of 13 FirstFirst ... 3111213
Results 121 to 126 of 126
Thread: truck isnt going to full mm command or timing?????
  1. #121
    Apr 2009
    ahh. Got it. but dosent it still need to drop below 2600rpm to become active? clearly not but couldnt the truck be at say 40mm3 and 3400 rpm? so pilot follows the fuel command over rpm?
    Thanks!
  2. #122
    Nov 2010
    Default truck isnt going to full mm command or timing?????
    Depends on how the pilot table is setup...mine is setup to shut off over xxxmm3@xxxxrpm and if it drops below EITHER rpm or mm3, the pilot becomes active again.
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
  3. #123
    Senior Member DieselMafialb7's Avatar
    May 2012
    Quote Originally Posted by 2007 5.9 View Post
    I seen that what are you using for refernce on that? did you get the email with screen shots i sent you?
  4. #124
    Nov 2010
    Yeah I got them, just haven't had time to respond..
    For reference...lots and lots of testing. Testing on the street, dyno...etc
    If it shuts off too low in rpm you'll get white smoke and rattle...and I know on the dyno that removing it when I do, does not loose hp.
    Les Szmidt
    2007 5.9 Dodge Ram
  5. #125
    May 2012
    Ahh i c ok great info les! Thanks
  6. #126
    May 2012
    So digging this back up as I couldn't get a answer on why my tune wouldn't work and the customer wants a different tune so again id be nice if someone could tell me why it wont work?
  1. Full flash gone wrong truck won't start !!!!
    By Collins in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 15th, 2012, 10:18 AM
  2. Replies: 2
    Last Post: January 20th, 2012, 02:35 AM
  3. How many MM3's can you command?
    By LBZoom in forum Duramax LB7
    Last Post: February 2nd, 2010, 12:15 PM
  4. What AFR do you want to command at Idle?
    By Loudmouth LS1 in forum Gen III V8 Specific
    Last Post: January 19th, 2007, 02:06 PM
  5. command vs actual a/f
    Last Post: June 9th, 2006, 01:50 AM
