Page 3 of 13 FirstFirst 12345 ... LastLast
Results 21 to 30 of 126
Thread: truck isnt going to full mm command or timing?????
  1. #21
    Junior Member kaiserbailey's Avatar
    Jun 2012
    click reply, then click on go advanced, then click the paperclip. You should be able to add it from there.
    Bill Bailey
    '05 Dodge 2500 4x4 QCSB 48RE
    FlashScan V2 waiting on 03-05 support
  2. #22
    Senior Member DieselMafialb7's Avatar
    May 2012
    see if this works
  3. #23
    Nov 2010
    Post a log of said conditions....
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
  4. #24
    May 2012
    ill have to go take one couple i have are way long ill make a short one asap anyone see anything i missed?
  5. #25
    Nov 2010
    I cannot see anything obvious...so a log is needed.
    Just to be clear...this ECM was NEVER touched by anything like a handheld tuner, the calibrations were NEVER changed??
    Les Szmidt
    2007 5.9 Dodge Ram
  6. #26
    May 2012
    Quote Originally Posted by 2007 5.9 View Post
    correct truck has been stone stock has 180k on it came in needing trans and injectors and wanted a tune been fighting it ever since
    also what you wanting me to log as its in groups just timing and mm?
  7. #27
    Jun 2012
    yea, I stared at it for a while, and nothing seems like it would be pulling timing.
    Bill Bailey
  8. #28
    May 2012
    Quote Originally Posted by kaiserbailey View Post
    i didnt think so either been pissing me off
  9. #29
    Mar 2009
    Subscribed.
    2002 Chevy Duramax with a few supporting mods.
  10. #30
    Lifetime Member anarchydiesel's Avatar
    Jun 2011
    try setting d0511 to minimum. Click image for larger version.
    Anarchy Diesel Tuning/ Advanced Injection Diesel Technologies
    EFI Live Cummins Beta Tester
    Duramax and Cummins Tuning
    423-506-7427
  1. Full flash gone wrong truck won't start !!!!
    By Collins in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 15th, 2012, 10:18 AM
  2. Replies: 2
    Last Post: January 20th, 2012, 02:35 AM
  3. How many MM3's can you command?
    By LBZoom in forum Duramax LB7
    Last Post: February 2nd, 2010, 12:15 PM
  4. What AFR do you want to command at Idle?
    By Loudmouth LS1 in forum Gen III V8 Specific
    Last Post: January 19th, 2007, 02:06 PM
  5. command vs actual a/f
    Last Post: June 9th, 2006, 01:50 AM
