Results 1 to 7 of 7
Thread: Question on Hooking LC1 up on 02 Camaro
    Jun 2009
    Default Question on Hooking LC1 up on 02 Camaro
    I'm finally getting around to install the LC1 on my car. The tutorial shows to hook the yellow and ground to efi live, but this is for v1. Is it connected the same way on the v2? all i need is to put the yellow wire (analog 1 output) from the lc1 and also the ground wire, and then i put both into the orange connectors, and that goes into the 0-5 volt ports on the v2. Is this correct?
    I thought i read somewhere you could use the serial out of the lc1 instead and then plug the serial cable directly into the v2, is that correct? if so it would be much easier. Also what do i need to do on the v2 to get it reading a/f if i use the serial cable? I have programed lc1's before for the analog outputs, can you program the serial output on the lc1 as well?
    thanks for the help.
    Hi gpr,
    see post #3 here: serial-port-cable-that-goes-to-v2
    The serial comms provides AFR, Lambda and EQR as read from the LC-1... when you program the LC-1's stoich AFR then this will modify the serial comms AFR.
    The serial comms pids are: EXT.WO2AFR1, EXT.WO2LAM1, EXT.WO2EQR1, EXT.WO2ST1 (and EXT.WO2xxx2 if you daisy chain two LC-1's);
    those pids can be automatically enabled by configuring the V2 BBx Config.
    Be sure to plug in the blank terminator plug into the LC-1 SERIAL IN cable.
    Default LC-1 serial comms connection
    SERIAL IN <-- terminator plug
    SERIAL OUT --> null modem serial cable --> FlashScan V2
    Jun 2009
    Great thank you so much joecar, and wow a quick response in the middle of the night!
    btw, i have a gender bender not a null modem serical cable. what is the difference?
    The gender bender does not swap Rx/Tx... you want these swapped which is what the null modem adapter does (it must say "null modem" on it)...
    or you can buy cables from TAQuickness
    or you can make your own cable.
    lol, it's daytime where I am at...
  1. hooking LM-1 to v2
    By BAD BOB in forum FlashScan V2
    Last Post: July 5th, 2010, 03:06 AM
  2. Question on LC1 with V2 and TA cable...
    Last Post: December 21st, 2009, 03:54 PM
  3. Question about lc1 wiring hook up
    By esco35m in forum General (Petrol, Gas, Ethanol)
    Last Post: June 11th, 2007, 05:26 AM
  4. Question regarding LC1 hookup for calibration
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: February 12th, 2006, 06:45 AM
  5. LC1/Flashscan voltage question..
    By Chris81 in forum General
    Last Post: October 11th, 2005, 10:01 AM
