I know it can be done but can't find out how. How do I set up my home computer so I can work on tunes on it and just use my laptop to flash the car.
All you should really need to do is have EFILive installed on both home and laptop computer. Then simply copy the tune file between systems, using network if you have that setup, or just a USB storage drive, floppy disk etc.Originally Posted by minytrker
Andrew
EFILive Crew
LOL. Just got the email notification of your post (pre edit). I only got in first cause yours was more descriptiveOriginally Posted by MN C5
Andrew
EFILive Crew
My home computer is in demo mode, can i just enter the key code in my home pc also?
Yup. That is about your only optionOriginally Posted by minytrker
Andrew
EFILive Crew
