Results 1 to 2 of 2
Thread: Daewoo matiz connection problems
    Jul 2012
    Default Daewoo matiz connection problems
    Another Australian newbie trying to find his way with ALDL!
    Using V4 i have managed to connect using COM3. It tells me the interface is connected. There is only one definition for Daewoos. When I press detect chatter, the program stops responding.( and basically locks up- Not responding)
    So if don't press the get chatter icon and go for the Get engine data it starts the macro's and then locks up again. (Also get Com timeout)
    I have a feeling that the Macro is not recognised by the ECM of the Matiz.
    Some help or information would be greatly appreciated from the gurus.
    In anticipation
    Yours mike
    Make sure Com3 really is the COM port that the ALDL connector is connected to. Sometimes the EFILive software will "see" a built in modem and it will appear to be the ALDL connector. If EFILive is trying to send/recv ALDL commands to/from a modem it will not work.
    Find out whether your ALDL interface echoes back the commands sent to it. If so you'll need to check the Max232 Echo checkbox in the property settings.
    If you are using a USB-Serial convertor cable, chances are it won't work. See this thread for more info... http://forum.efilive.com/showthread....adapter-issues
  1. Flash Scan box to usb cable connection problems
    By cmitchell17 in forum FlashScan V1
    Last Post: July 3rd, 2009, 04:17 AM
  2. Australian Daewoo Lanos 1999 Strange Data
    By leibhold in forum EFILive V4
    Last Post: November 25th, 2008, 12:40 AM
  3. Problems with V2 Connection
    By SV8346 in forum FlashScan V2
    Last Post: February 26th, 2008, 12:44 PM
  4. Connection problems
    By monaro308 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 18th, 2008, 02:14 PM
  5. PCM Connection Problems
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: February 24th, 2005, 06:09 AM
