I trust you. The reason I ask is that you are not sure what the affect of each change is, when you change both together. The idle airflow "parked" table is based on IAT. Idle airflow is ECT.Originally Posted by SSbaby
2003 red vert
Mods:
LPE 100mm MAF
RPM Level 6/4L60e trans
3.42 gears
Yank SS3600
1-7/8" AR headers
Z06 exhaust
470rwhp 437rwtq
Ah-ha... I wasn't aware of that! No wonder I had to fiddle around with it a few times - I did change IAC values from -8C upwards as well, although I assumed that the 60C+ readings were of most relevance in this topic hence why I quoted for IAC & IAC Parked temps > 60C... I must have just 'fluked' it this time!Originally Posted by jfpilla
But it idles a lot better than it did. Thanks for the heads up, jfpilla! 8)
