I attached the log and current tune with VE table basically dialed in as close as possible with my LC1-serial WB. What I am thinking"which may be completely incorrect" is that the narrow bands are still doing LTFtrims on the fuel and I wanted to log these and make a BEN map to fix what it wants on my VE table before returning it to commanding the semi open loop.
I tried to do this logging the LTFT's and maaking a BEN map but am missing something somewhere. The BEN correction factor does not move across the "MAP" with manifold pressure like it should
any help would be greatly appreciated. Thank you in advance.
Robby
