Results 1 to 7 of 7
Thread: 06 LLY wont start
    Jul 2012
    Default 06 LLY wont start
    Installed DSP5 switch, then flashed the ECU. now truck wont starts, EFI live says "ECU not detected".
    It was detecting it after the switch install, so I don't think that was the problem.
    I check fuses but couldn't find any bad ones and I can get power from the OBD port.
    if i try to display info VIN/OS for GPM I get VIN: Unknown opSys:12597107
    if i display for TCM i get the correct VIN.
    What should I try next?
    May 2009
    Full flash stock tune back in
    Jul 2012
    Quote Originally Posted by cumminsDK View Post
    would love to, but as far as EFI live is concerned the ECM isnt there.
    Pull battery for a few minutes then try to full flash it again.
    Jul 2012
    disconnected the positive wire from both batteries for ~40 mins, still no ECM detected.
    Can you post the tune up? Or if not (as in it may have been purchased from someone therefore shouldn't be put out in public), can you Email it to support@efilive.com
    Maybe there is something wrong with the file that has bricked the ECM. As far as I know Bosch ECM's don't die very often.
    May 2009
    I just had this happen on 06 flashing with V7 got stuck at 1988k. Stopped it and used V8 no issues
  1. Wont start now.
    By GM-OOD in forum Duramax LLY
    Last Post: July 10th, 2012, 11:37 AM
  2. 454 Wont start.
    By notgoodenugh in forum Vortec V6/V8 Specific
    Last Post: February 4th, 2012, 12:30 PM
  3. help truck wont start!
    By chev in forum General (Diesel)
    Last Post: March 29th, 2010, 02:39 PM
  4. wont idle at start up
    Last Post: May 9th, 2009, 04:56 PM
  5. efi live wont work with lly?
    By titanspanker01 in forum Duramax LLY
    Last Post: February 27th, 2006, 01:23 PM
