Well this weekend I had the opportunity to see whats really involved in collecting the all important "injector data" we so often talk about online. Over my career as a calibrator I have had my share of issues with poor quality injectors, lack of data and bad data. Now that I have a good understanding of how critical it is AND the effect it has on drivability and overall performance I'm not looking back.
We flowed a few different sets of injectors that are currently being marketed and its quite concerning to say the least. Many people think that as long as they have the size of the injector they are all set...wrong answer! Some of the things that are critical are;
Injectors stability and predictabilty at pulse widths below 4.00 ms
Overall injector flow rate (static flow)
Consistency between sets of injectors
Proper spray pattern
The above items noted above where all observed this weekend. We also ran some stock unmodifed sets to compare to and observed the effects of "drilled" injectors, especially when not done correctly.
The tests performed where done using the SAE J1832 test methods which is the test method that all injectors in the OEM world are tested by. Its a very specific test which includes using a certain fluid as well as warming up the injectors for so many cycles before testing.
Its a decathalon of testing! I was quite surprised to see how some of the injectors are completely uncontrollable at low pulse widths. This now confirms why a few cars we tried certain drilled injectors on where very hard to get good fueling control. According to SAE the injectors must be within 3%...the injectors we tested where closer to 12% off.
I am not at liberty to discuss which injectors we tested but if your injector supplier doesn't test with the SAE standard and you claim to be good calibrator your wrong...
Those who haven't read this write up will have a better idea of what we experienced during our tests
http://www.calibratedsuccess.com/Ass...ingDrilled.pdf
Howard
